look what i make to my car and i still have cooling problem
HI how r u all
I have mustang 1992 and I put 351 engine whith automatic transmission
I put these thing
Fan Clutches
Fans, Mechanical - rnb-620-112
Radiator Caps - sum-380060
Radiators - sum-380451
Thermostats, Mechanical - sum-360160
Water Necks
Water Pumps, Mechanical
Hose Kits, Cooling System - fms-m-6052-b
the last thing i wrote b cuse i have cooling problem that is the tempreture on the high way is good under 160. but when i am in city it fastly the tempreture came 192 ( waaw) and then i must stop the car so that the tempreture came down ( which is so slowly) to come back home
what do u think is the problem i am so sad and tired
note most of my parts i bought from summit racing
thank u
I put these thing
Fan Clutches
Water Necks
thank u
RE: look what i make to my car and i still have cooling problem
ORIGINAL: madam_zezo
HI how r u all
I have a 1992 mustangthat I put a351 engine with an automatic transmission in
I put these things on the engine
Fan Clutch
Thermostat, Mechanical - sum-360160
Water Neck
Water Pump, Mechanical
Hose Kit, Cooling System - fms-m-6052-b
the last thing i wrote because i havea cooling problem, the tempreture on the high way is good under 160, but when i am in city traffic, the tempreture rises to 192 ( waaw) and then i must stop the car so that the tempreture can comebackdown so i canmake itback home
what do u think is causing this problem? i am so sad and tired
*note most of my parts, i bought from summit racing
thank u,
Fez
HI how r u all
Fan Clutch
Water Neck
thank u,
Fez
maybe your fan is not enough to keep it cool or the radiator or something is clogged. Try pinching the radiator hoses while the car is running, to make sure that the coolant is flowing, when you squeeze the hose you should feeling the coolant flowing through it, if you dont then its clogged somewhere. Oh and I notice you didnt say anywhere that you bought coolant, make sure you coolant level is good and that there are no air bubbles in there.
Thank you Yes, this point being made by you, but what do you mean, my brother coolent is it for transmission Crankshaft or what?
note : sorry for my
Weak English [/align]
note : sorry for my
coolant goes into your radiator, it is also called radiator fluid. you have to make sure that is full and doesnt have any air bubbles. I cant think of anything other than that since you said that all the parts are brand new. Just make sure that the fluid is flowing and you have plenty of it.
What is your first language?
what degree rating is your thermostat? it should be somewhere between 180 and 200.
with your problem it may be any of the following:
-thermostat is too high--190 or 200. I'd get a 180 degree thermostat.
-make sure you put the thermostat in correctly. in some cars it can be put in backwards. check with the auto store you bought it from. I think you should have the springs pointing toward the motor --- NOT the radiator.
-make sure your fan blades are pulling the air---not pushing. you can tell this by simply taking a few scraps of yard/lawn grass and dropping them in front of your radiator. if they are sucked into the radiator likely the blades are going in the right direction. if not then take the fan blades off and flip and reinstall. then do the grass trick and see if that helps.
hope this helps.
guys---correct me if i'm wrong on the direction of the thermostat.
hope this helps.
just to be sure, take your thermostat out and try running it without and see if it still gets hot. you can also check to see if the thermostat is working by putting it in some boiling water and looking to see if it opens, and also itwould be a good idea to have a thermometer to check at what temp it opens at if you dont know what it should
Thank U guys
My thermostat range is 160 F. and i tried to take it out and I feel the hot of the car is littele better
but if u said that the tempreture between 180-200 is normal then that mean my car is fine .am i right?
and by the way I am from Kuwait and My first languege is Arabic
ShaneB26154
35
03-04-2021 04:05 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
HIS S-197
08-10-2015 05:47 PM
