Another engine, what do you guys think?
RE: Another engine, what do you guys think?
Sounds like a pretty good deal, any history on it? How many times has it been re-built (bored, decked etc..) Has it been magna fluxed or dye checked for cracks? Aside from any of those fears it seem like it would be decent buy.
ORIGINAL: r.barn
Decent price. Cam is on the tame side for sure though.
ok, the engine had been rebuild once, as for everything else i am not to sure. It has about 5000 KM not miles on it. And he has a potential buyer but i am nbext in line and i think i can get it for a good price 800 or cheaper. He is a greatseller and hes has been referred by many i have talk to about him. So i think it mihgt be a go if the potential buy changes his mind. if not i have some opther parts.
* WHAT DO YOU GUYS THINK OF THESE PARTS, SIMILAR TO THE ABOVE.*
.030 over with flat top 4 valve releif pistons
Std. volume oil pump and hardened drive shaft
Blue Racer hyd. flat tappet cam part#WG-1165K
Specs are adv. dur. 280/290
duration at .050 214/224
Lift with 1.6 rocker 472/496
Lobe seperation 107/117
Blue racer hardened push rods part#WG-1443-16
Double row 3 key way timing chain and gears installed at "0" adv.
Crane lifters and a crank turned 10/10.
probably all this stuff for 500 CANADIAN. WHAT DO YOU GUYS THINK?
i think blue racer = junk and your better off with the first motor listed.
when are you gonna make up your damn mind about what motor your gonna use anyways? [&:] [8D]
ORIGINAL: my77stang
SOON I PROMISE., i need one before Dec. though. the search will narrow one day
