351 Mustang
S/C and heads/cam for 351W
Old 10-02-2007, 08:42 AM
Force4
Force4's Avatar
Default S/C and heads/cam for 351W
This winter im going all out. My first intentions were just to do a heads/cam swap but im going to through an S/C on top of that.
I was thinking for heads because i dont wanna gut my internals id do Twisted Wedge 195cc heads but i dont have a good preference for a cam.
Also for the S/C i was thinking something along these lines:
http://cgi.ebay.com/ebaymotors/FORD-...spagenameZWD1V
What you guys think?
Force4 is offline
Old 10-02-2007, 08:49 AM
MadMan@TheWheel
MadMan@TheWheel's Avatar
Default RE: S/C and heads/cam for 351W
You will not be happy at all with 195's on a S/C Windsor application.
You will want something above 200cc's 225+ should be you aim.
Cam is important in this type of application, so you might want to investigate a custom grind.
Barry Grant in my opinion makes amongst the best blow through carb on the market, a carb designed for the blow-through application would be good insurance against cylinder leaning, so you might want to look into that also before you by a package deal.
Look into component shopping and peicing it all together first, that package looks like a decent deal, but in that application the carb is everything, so you may want to buy a higher end carb. But it is up to you.
MadMan@TheWheel is offline
Old 10-02-2007, 10:41 AM
r.barn
r.barn's Avatar
TW's are fine with right cam
Forget that s/c, you can get a turbo kit for a just a little more
or fab your own for same and make more power
watch out when trying to mount s/c from a 302 on to a 351 in a Foxbody
they dont always like to fit properly and clear the hood
Can be done but usually requires custom or modified mounting bracket
r.barn is offline
guitarman376
09-30-2015 05:54 PM
LiquidDrink
09-29-2015 10:06 AM
Soldier GT
08-12-2015 03:46 PM
Mustang88LXKid
02-29-2004 08:01 PM
WNDSOR
01-30-2004 09:47 AM
Quick Reply: S/C and heads/cam for 351W
