Fox 351w Flywheel
Fox 351w Flywheel
Hey I've got a 91 Mustang with a 2.3 and an auto. I took the 2.3 out and in the process of installing a 351w carbed, with a T5. The engine I have came out of 95 econoline. I've been reading and searching in these forums and found a lot of usefull info. I have installed the convertible mounts for a little added clearance. Does anyone know of a Edelbrock intake and carb setup that will fit under the factory hood? Also, I think that the 351 is 28oz balance. I know that the stock '95 clutch for an F-150 has the same input shaft diameter and spline as the mustang clutch. However, the diameter of the flywheel is 14.241" and 164 tooth, and the clutch disc is 11". Will this clutch setup,and factory starterfit in the T5 Bellhousing? All of the 28oz flywheels I find for the Mustang is 157 tooth, what factory starter will work with 157T Flywheel? Any help will be much appreciated. Thanks!
junior04
09-28-2015 10:53 AM
