351w mustang Sway Bar
I'm currently in the process of swapping a 2.3 to 351w. Everything fits like it should. I have a dual sump swap oil pan with convertible motor mounts. It fits almost perfect except the front sway bar. Is the 2.3 sway bar different? Or is there anything else I can do? Thanks for your help.
RE: 351w mustang Sway Bar
I have the same problem with my 1980 which was originally a 2.3 turbo.
I think the 2.3 may use a different sway bar because some of the people I've heard from didn't have any problems but I don't know for sure which engine their cars originally came with. Who's oil pan are you using?
I'm looking for the measurement between the rack and sway bar on a factory 5.0 Fox body if anyone out there has a minute to check......
what issues are you having with the sway bar?
if its hitting the oil pan on the front of the motor... you could modify the end links... shorten them. this will bring the swaybar slightly forward, and away from the oil pan.
ORIGINAL: AdderMk2
I cut and transferred mounting holes to make a couple of shims out of 1.5" square tubing to lower the sway away from the oil pan and used longer bolts to install. It was a quick and painless mod. If we're talking about the same bar that connects the frame ahead of the motor.
The car was originally a 2.3L Turbo.
Indy
Indy
inyadreems
08-21-2015 09:10 AM
