351 Mustang
Where to go from here..
Old 10-24-2007, 11:46 PM
STeeL25T
STeeL25T's Avatar
Default Where to go from here..
Hey, I'm the new guy. I just picked up an 87 GT, only had it a day so everyone on it is what it came with. Here is what I was told it has:
Engine mods:
359W (351 .040 over)
Holley 750 carb just rebuilt with a Holley trick kit
Offenhauser 360 intake manifold
Stock heads with 1.6 roller rockers
Lunati cam
Forged Eagle crank and rods
Forged Wiseco pistons
Accel coil and plug wires
Mallory points eliminator kit
3 core HD radiator with electric fan
Transmission:
Tremec World Class T5
Astroperformance billet steel flywheel
Ram clutch
BBK adjustable clutch cable and billet clutch quadrant
B&M short shifter
Exhaust:
Chrome headers
2.75" exhaust with custom h pipe
No cats
Magnaflow mufflers dumping in front of the rear axle
FRPP 3.73 gears
Cosmetic mods:
3.5" lift off Harwood hood
Completely stock suspension and breaks
I'm not even sure what a points eliminator is, I'm new to V8s and carbs. He said the heads on it are hold it back so I'm sure I'll be wanting to change those out with something.
The body looks horrible so I'll be dealing with that for the time being, but I really want to know what to expect from the current setup and where to go from there.
STeeL25T is offline
Old 10-25-2007, 11:07 AM
Does Not Exist
Does Not Exist's Avatar
Default RE: Where to go from here..
Get a good set of heads then throw some juice at it. Probably gonna smoke that tranny if you do that...so look into a solid tranny sometime too.
Does Not Exist is offline
Old 10-25-2007, 04:17 PM
STeeL25T
STeeL25T's Avatar
The guy I got it from tried to sell me the auto tranny ("A" something) with it with some other stuff for an extra 1000 but I declined... is the 5 speed bad?
STeeL25T is offline
Old 10-25-2007, 06:07 PM
Does Not Exist
No, your 5-speed is just fine. It'll probably give out rather quickly if you did what I said though.
With your current setup you'll be just fine. Get some decent heads and you'll be kickin some ***.
GstangT
02-25-2007 10:52 AM
proteinshake03
02-15-2007 11:24 PM
howifeel2
01-25-2007 04:14 AM
dvs_03gt
01-13-2007 08:16 AM
Quick Reply: Where to go from here..
