How much Nitrous can my 408 take
RE: How much Nitrous can my 408 take
Ya it has H beam rods What would timing be set at with a 200 shot and what jets should be in the carb with that im new to the carburated stuff i Think the car was prob a 10.50 .60 car as it set it just didn't have a big enough converter and i also think it wanted a bigger cam it ran a 10.9 in 85 degree weather i couldn't imagine a 200 shot of nitrous
ORIGINAL: Aikin9350
if you got 6.250 rods you got a thicker top land on your pistion than the 6.200 rod ,which is what i got .i would still go 250 with timing set to 20. just run c -16 gas straight. i got 11.7to1 also. i haven't run mine in a year.
So when im just driving my car around on the street what should my timing be at. The guy i bought the car from said it was advanced and he said it was around 35 does that sound right
ORIGINAL: Aikin9350
So even if my car is still 10.5.1 i should still run racing gas in it
I got an msd distributor and im pritty sure i have a 6al box manybe i should build a turbo kitfor it.I don't know cause i would love for the power to be there all the time. there are so many options
its got to be a msddigital 6 box
as for turbo you got to much compression
id be happy running what youre running right now.
nitrous can hurt your motor , if youre not careful, alway got to be on top of the timing temp outside and bottle pressure,
i hurt many of motors to know what to do and what not to do. i never hurt a motor without nitrous.
things like bent rods.
i got a 94 351w block, with no girdle either running 10.09s 6 times back to back runs. 6 run burnt the clutch disc up.
How much is that 6 box the reason i had said turbo is because i haven't got my pistons so i may get lower compression ones but i know nitrous is cheaper i have the cheater nitrous kit already with 150 through a 250 shot. Id love to have the turbo power always there I just like to get my car down to around 10.50 on motor which i think is very possible what you think i should do so many options....
---RICHARD----
[IMG]local://upfiles/16852/48E448DA957A42D69DA2F70E29A23BC8.jpg[/IMG]
[IMG]local://upfiles/16852/DB46728E39CB4D83A8D3330FA712B0EC.jpg[/IMG]
---RICHARD----
