4cyl to a 351m???
4cyl to a 351m???
ight yall...well i thought the swap i was doin was a 4cyl to 351w...but once i took it outta of the truck..i thouhgt it was a cleveland...now i find out its an 351m...so its gettin worse and wrose lol
i know these arent the bes motors to start of with..but now im just tryin to work with wat i got...and im usin my buddies garage and im just tryin to get my ride outta there with some progress made...so does ne one know if the 351m will swap into a 4cyl?? the only thing i think tht might give me trouble is the c6 and i dunno if itll fit underneath..so if ne one has ne advice or knowledge of this motor and if itll work...please let me know (this is just an option until i can find an affordable windsor to drop in...i just wanna drop somthin in the stang and see wat happens..and i gotta get some of this stuff out my buddies garage lol)
RE: 4cyl to a 351m???
1. yes it will fit
2. yes the C6 will fit
D. dont care what anyone says, the M motors have potential to make more power than any W platform (they are basically Cleveland motors anyways)
It can be done but, the expense will be more than buying a rebuilt Windsor. Headers and oil pan will have to be custom made. No one makes them for that swap. A C6 will fit. Headers usually run about $700 and the oil pan wil be atleast $400. You also can't use the early (67)73) mustang headers for the swap. They won't even be close to fitting. Truck headers won't fit either. This is why you see so few people swapping 351C's in them. In the mid 80's a company did offer the swap but, even then the kit was over $1000. It hasn't been available since around 89-90 and are pretty much impossible to find.
i recommend manifolds, you could port them a bit if you like, but really for a stock to mild 351M your not going to gain all that much by swapping to headers anyways as long as you have a quality dual exhaust setup
They won't make near the power a healthy windsor will. The M heads aren't near as good as a good cleveland head. For the money spent you will be lucky to get half the power. You will get torque but, thats the reason they were truck motors or in big cars. There is very little aftermarket for them. Also, the exhaust manifolds won't work in a Fox body. The angle causes issues with the steering shaft and the firewall. Tried it before with 70 model Cleveland manifolds. They have the weaknesses of the Cleveland without the performance of one. They do make good boat and truck motors but, they don't make good performance motors.
yea ive been doin some sufferin on the net lookin for other folks who have been doin this...but its kinda been 50/50..some says its an ok project to do..and some say its not lol..but im just gonna try to work with i got for now
so my next question is that.....im assumin ill need a differnt driveshaft (am i right)? lol..and im mos def swaping the rear end with an 8.8..but i was wondering wat would be good gears to use with the 351m (slighty mod'd)/c6 tranny? cuz i know it has a lot of torque so im thinkin maybe if its geared right maybe itd make it run a lil better?
ORIGINAL: my77stang
1. yes it will fit
1. yes it will fit
dont mean to jack the thread but good luck with your project
The C6 will make it harder to find headers due to the bellhousing. With gears, I would start with 3.55 to a 3.73. Don't go much lower due to RPM's. Cleveland and M motors have an oiling issue at high rpm's. They need oiling restrictors. SVO blocks corrected this issue.
