connecting rod question
http://cgi.ebay.com/ebaymotors/NASCAR-LENTZ-CONNECTING-RODS-CHEVY-FORD-DODGE-carrillo_W0QQitemZ270150112077QQihZ017QQcategoryZ3 3623QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
if i get a 4in stroke crank, can i use these rods and what ci would i get? oh yeah, its a 351w
isit even possible use rods not specfic fo the engine/crank?
i also saw some with a 6.250in length, will these wrk also?
RE: connecting rod question
Like stated just buy a kit. If you were to buy those, You would run into issues with the psiton compression height. You'll run into major problems.
just buy a kit including a 4" crank, 6.125" rods, and a 1.35 compression height piston, All that with a 4.03" bore will yeild you a 408!
Nik!
Nik!
Those are an awesome set of rods!! Now, like everyone has said, just order a rotating kit! The reason why is this......look at the rod journel size listed......1.88.This is a Honda journal size. You would have to purchase a custom forged or billet crank with that sizing to use them
Casey
Casey
TfcCDR
09-14-2015 12:08 PM
