Educate me on 351s
RE: Educate me on 351s
I got a 500hp 408w. Cost me about 6500. They're cheap. Are you keeping your car injected or carbed? If you went with a carb you could easily knock about1000 or so off the cost of what I had to pay to build the same thing
wow.....I thought you would say something along the lines of 3 grand....are you guys building these or having them built for you? Because I'm planning on doing everything other than the machine work
ORIGINAL: boostin95cobra
You moving back to Colorado when your done with school in Qatar?
I have around 8500 in mine aswell and not much of that is in machine work since I know the guy doing the machine work. To save the money you need to stay with a 351 .030 over. You throw a stroker kit in there its atleast 1000 bucks for a cast one with ok rods and ok pistons.
Like I have said before a 357 with 190-200cc heads, 11 to 1 compression, big cam with the correct valve train, andportmatchedand rpm matchedintake and a decent ignition system can make great powerand turn 7k rpm if desired. You can leave the stock bottom end in without worry if your only going to 6500 rpm. That setup will only run you 3-5 grand and will make plenty of power for a light little fox.
These can save ya the hassle of fooling with stuffwhen your not well versed in the motor they aren't a custom setup like most guys here are running but they get the job done. Just have to tac on that extra 1000 dollars for headers for the swap into the fox and a carburator ontop of the power pack cost.
POWER PACKAGE TOP-END KIT #2093 451HP/433 LB-FT OF TORQUE INCLUDES:
Part No.
Description
2281
Performer RPM Hydraulic Roller Cam
51259
(2) Performer RPM XT Cylinder Heads, complete
6991
Timing Cover Gasket and Seal Set
7364
Cylinder Head Gasket Set
7581
RPM Air-Gap 351W intake manifold
8485
Intake Manifold Bolt Kit
8553
Cylinder Head Bolt Set
7820
Performer-Link Timing Set
Part No.
Description
2281
51259
6991
7364
7581
8485
8553
7820
i'm building mine, i have a friend with a machine shop to so i'm getting a good deal he also ported my heads.... the biggest thing i will suggest is get light pistons and rods... i used billet I beam rods 6.250 inch and mahle pistons, my rotating assembly is ultra light... only thing is my crank looked like swiss cheese when it came back after ballance LOL.... IT'S GONNA BE A FAST REVIN ****!
jerod187
03-08-2009 12:08 PM
