thinking about a 351w? what do you think?
#21
RE: thinking about a 351w? what do you think?
i wasnt sure with the light bulb, haha. What would you recomend for a set of heads since you have built a pretty mean engine?
#22
ORIGINAL: kweb288
Completely my fault BTW, Too much ignition advance combined with a 300 shot .
Oh well live and learn (I hope).
The car did run its best N2Otime 9.12 @ 152.44with these heads though.(That would be before I broke it)!
Currentlyon the caris a pair of Canfield Part# 20-450-58C. 2.08" Int. 1.625" exh. 58cc chamber.
Ran 10.74 @ 130.18 NA with these Torquey bad boys!
Vic Jr. is an open chamber head, Canfields are a closed chamber design.
Either one should do you right on a large mill,topped 600hp NA with both.
Vic Jr. 647hp @ 7400 rpm 359 cu in.
Canfield 615hp @7100 rpm (364 cu in.) Don't Ask!
#25
ORIGINAL: kweb288
damn those are some nice #'s... were he vics unported? and what chamber size were you using?
13.8:1 actual comp. w/ domed Venolia slugs. .043" copper head gasketsw/ Hylomar sprayed on both sides (Gasket Sealer) seal it up.
They also have 2.08" Int. and 1.625" exh. valves.
2" long tubes w/ 3 1/2 " collectors let out the bad air.
Canfields on motor in picture.
[IMG]local://upfiles/95778/FE97E566572F455A9B9DCE16089FD265.jpg[/IMG]
Military_man_88
12-02-2015 10:20 PM
