stroked 351's...What head,cam,intake combo's you running (NO CARBS)
I was wondering what heads cam intake combo's you guys running out there? What times you running? What compression ratios? What weight you at with driver?
1. heads
2.cam
3.intake
4.compression ratio
5.weight of car and driver
6.power adders
7.timeslips
8.rearend gears
9.auto or stick
Last but not least......How often and how far do you drive and on this combo?
I was wanting to see if my combo compares to others.
1. heads
2.cam
3.intake
4.compression ratio
6.power adders
7.timeslips
8.rearend gears
9.auto or stick
1.heads - Victor Jr. 60cc
2.cam - Custom Grind Comp Cams Cam
3.intake - Trickflow
4.compression ratio - 10.08:1
5.weight of car and driver - ~3150
6.power adders - Nada
7.timeslips - Not Running Yet.
8.rearend gears - 4.10's
9.auto or stick - 6-speed T-56
1. heads
2.cam
3.intake
4.compression ratio
6.power adders
7.timeslips
8.rearend gears
9.auto or stick
1. heads
2.cam
3.intake
4.compression ratio
6.power adders
7.timeslips
8.rearend gears
9.auto or stick
Hey everyone, I am Jacking/renewing this thread(sorre Red) because I am in the process of starting/building my swap and I am looking for some good ideas, the original posters question was right where it needed to be without the compare statement. so PLEASE continue this thread with your combo/time info.
Thanks
Thanks
D9AE block .040" over
Eagle nuetral balance crank 3.5"
Eagle H beam rods
KB domed pistons
ported Edelbrock Victor Jr's (~305cfm @ .650)
COMP Cams XR292R solid roller
TFS Box R manifold
Acufab 90mm TB
97mm DBX MAF
42# injectors
MSD ignition running on 95 ECM with SCT tune
compression ratio is 10.86:1 with Fel Pro gaskets
Tremec T56 (2.97, 2.07, 1.43, 1.00, .80, .62)
3.73 rear end, 31 slpines
255 lph in tank
hope this helps.
Eagle H beam rods
KB domed pistons
TFS Box R manifold
Acufab 90mm TB
97mm DBX MAF
42# injectors
255 lph in tank
hope this helps.
