Anyone want to guess what hp I'm making?
I realy want to know if I make it to 400hp?
351w .030
Keith Black 11>1 Comp ratio
Isky Roller Cam http://www.iskycams.com/timingchart....ber=371275/284
Roller rockers
351w -69 cylinder heads with bigger valve and match port with
Ford Racing dual plane intake
Holley 600cfm DP 4bbl
Distributor from Petronix
Long headers
2,5" turbomuffler (sidepipes)
351w .030
Roller rockers
Long headers
same maybe 350 hp at the flywheel. get rid of those heads. If i remember correctly the AFRs fit ont the 351 w motor. Get a set of those and you will be in business. oh and new heads wont help much if you dotn have a bigger carb. that thing is way too small. Go 750 or 800 cfm.
doughtful,
I have a 351w bored to 357w
Edelbrock aluminum Performer RPM Heads
Edelbrock Performer RPM AIR GAP Intake
Edelbrock performer RPM Camshaft (it was a kit)
650cfm 4bbl carb
at the wheels I made 315whp before getting it tuned. (roughly 365 flywheel?)
Honestly, before I had my heads cam intake, with the stock cast iron heads my windsor only put down 225whp and 325torque. (maby 280 flywheel)
650cfm 4bbl carb
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
