351w making 400rwhp help
I have found a 351w for sale here for $250 and he would sell me a C6 for $100. But I'm not a fan of an auto so I will just be picking up the motor and accessories.
anything can make big power just need big bucks but as far as the motor go see if its in good condition i don't see why not, you said you would be rebuilding it anyway but i would most likely keep it in a garage to me dropping it in to just pull it later and rebuild it is more of a headache. (then again you might not rebuild it for like a few months and a motor taking up lots of space doing nothing isn't fun either)
wait wait wait...
not being able to make NA power on a modular is BS.
yes F/I is the easy way to do it, but of you want 400rwhp, then you can get there no problem with a mod engine.
either stroke and poke it out, or go with a 5.4 block.
use some new TF TW heads and port them, match them with a good set of modular cams, rev it to 7000rpm, through longtubes and i'd be willing to bet most anything that 400rwhp will happen.
and keep all your accesories
and be lighter than a 351W
and look stock
and not need all the BS swap parts.
if you want a pushrod engine, get a pushrod car. otherwise, enjoy the benefits of a superior design and make it work.
hell id be more proud to make big NA power on a modular than a pushrod.
why?
because like you said, no one does it.
and look stock
why?
^^^ Good points! I have been going back and forth with what I want to do, 5.4 or 351w. Thing though is with a H/C/I 5.4 I would be making around 400rwhp. But I could add cams and a 100 shot to my current set up and be making that or close to it.
I have been thinking about what I want to do lately. I have priced up approximate costs of the 5.4 swap and the 351w swap. When I posted this thread I was hoping just to do a half assed swap, save some money now and spend later to make it what I want. But I have come to the conclusion that if I am going to do the swap I am going to do it right, not half assed. So the 400rwhp isn't what I am looking for, it's the 351w that makes good power, runs in the 10s at the track and has street drivability.
On a MOD Motor just bolt on some trick flow heads and supercharge it.
Forge the bottom and get more .
They boost a Forged 5.4 and get 500 Crank HP.So doing it Naturally will cost much more than it is worth.
400rwhp is quite a lot.
The 351w will do it .
http://www.mustang50magazine.com/tec...sor/index.html
wait wait wait...
and look stock
why?
and look stock
why?
If I where you......
buy a good nitrous kit. spray your car with a 125shot for fun.
build up a 351w in the mean time, and have all parts ready to go. then do the swap. that way if it takes you a year or so to get all the parts, your still driving your car, and having fun while on the bottle at the track while you get everything ready for the swap.
a 408w with 205-225cc heads, a decent cam can make 400rwhp pretty easy. Add a 200shot ontop of that and its a absolute beast.
im planning on swaping a stroked 351 into my fox, but my goal is 500rwhp, before the 200 shot.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
