Passenger tail light problem
So all of a sudden my passenger tail light only works when I unlock the doors remotely and when I have my headlight turned on. But when press on the breaks the passenger side will not get brighter and when i lock the doors only they don't light up. I have searched the forums as best I could and couldn't quite find anything that matched my problem.
I've checked the fuses and i don't see anything blown but i could have missed something. Would there be something else i need to check or am i just way off base all together?
Did you keep your car outside during a heavy rain? Check to see if your carpet is damp. Pull the carpet on the passenger side just under the black box to see if it is wet under there. It could be the dreaded leak. Not all Mustangs have that problem but many do. There is a TSB on it of you find your carpet wet.
So far (knock on wood) I have not had that problem. I do keep a car cover on it, so that may help prevent it.
There hasn't been any heavy rain just snow mostly. The carpet hasn't been damp from what i can tell and i looked in the kick panel and nothing seemed corroded and it didn't smell musty or anything. Would snow melting cause the same effect?
I've been reading about this leak in different threads hopefully i'm not in that boat
