Zex nitrous
RE: Zex nitrous
ORIGINAL: stang13
does anyone know if the zex kit requires a reflash on an 05 4.0 auto? thanks
RE: Zex nitrous
I know you had this setup scrimg but how hard was the install? Is there a button you push or does it just turn on at WOT? I think i might get this kit. Also if I stay with the 75 hp shot will my engine safely handle it. I know you lost a piston but I think you where pushing more to it. Also would you recommend a dyno tune if I did install the nitrous?
RE: Zex nitrous
scrming blew a piston cause he got a little greedy and sprayed a 125 shot too low in the rpm range. (something like 2000 if I remember reading correctly)
The 75 shot tuned correctly is quite safe. I'd suggest a custom dyno tune with any nitrous system. There's too much that can go wrong that only a dyno with a wideband A/F meter can tell you.
Don't spray below 3000 (at least not until you're comfortable doing so). Only spray at WOT.
RE: Zex nitrous
ORIGINAL: chadlet
Ok but do you think the stock rear end would hold up. I plan on getting the t-loc with 373 gears but can only get one or the other.
