First Time Track Results - Page 2 - MustangForums.com
Old 10-16-2006, 01:56 PM   #11
rygenstormlocke
rygenstormlocke's Avatar
Default RE: First Time Track Results
Quote:
ORIGINAL: chadlet
They were at 32 psi.
I used to run my at 30psi. Fitebikeco runs his at 25psi and got some good results.
rygenstormlocke is offline   Reply With Quote
Old 10-16-2006, 02:05 PM   #12
chadlet
Thanks I will try that next weekend when I go back to the track. Also right towards the end of the runs it shifts into 3. Should I place it in 2 and just leave it there? Also everone says to increase my shift pressure but I have it turned up to 25% but it does not seem to effect the shift at all. At WOT throttle it seems to shift at about 6000 rpm but was told by scriming that are gauges are off a little from the factory. According to most dynos I have seen the power starts to fall off past 5500 so wouldnt you want to shift there. Only problem with that is I cant adjust the RPMs it shifts at, just MPH. Any suggestions.
chadlet is offline   Reply With Quote
Old 10-16-2006, 02:12 PM   #13
rygenstormlocke
Quote:
ORIGINAL: chadlet
25% is the max setting on the XCAL2, so leave it there. Also put your car in drive, with OD off (this puts it in 4th gear). That is how you want to launching. What RPM are you trapping at?
Old 10-16-2006, 02:18 PM   #14
chadlet
Not sure what rpms Im trapping at I know that right before the finish it shifts. So I would quess that my rpms are low.
Old 10-16-2006, 02:27 PM   #15
rygenstormlocke
Yes, I would remove 2MPH from your 1-2 shift, and add 2MPH to your 2-3 and 3-4 shift. Make sure your OD is off on your runs. Its possible that your car shifted into 5th on that pass.
Old 10-16-2006, 02:32 PM   #16
chadlet
Ok I will try that also this weekend. How do you feel about a used auburn LSD? I know I should buy new gears but what about the LSD by itself. Also are nittos good drag radials?
Old 10-16-2006, 02:57 PM   #17
rygenstormlocke
Quote:
ORIGINAL: chadlet
I'm not a fan of anything used in the rear end, but have heard of people getting used LSD's that work well. As for DR's, I run the M&H cause it is a 28in tall DR and lowers my effective gear ratio. But I'm switching to MT's next season. Most guys at the track don't do Nitto DR's that I have talked to. Everyone swears by MT's though.
Old 10-16-2006, 03:00 PM   #18
chadlet
Ok well thanks for the help I will let you know how it goes.
Old 10-16-2006, 04:47 PM   #19
boss 244
I'd say thaqt was pretty damn good for a first time!! way to go!!
boss 244 is offline   Reply With Quote
Old 10-17-2006, 02:28 AM   #20
chadlet
Thanks I plan on going back this sunday and hit 14. LOL but thats what I want. No I havent changed my fuel filter or my spark plugs. I do run royal purple oil though.
Legendary Hurst shifters - up to $50 rebate carid General Tech 1 07-08-2016 09:55 AM
Car died while driving... StalkerGT 5.0L (1979-1995) Mustang 13 09-25-2015 02:41 PM
Huge Savings from Lethal Performance.com!(Whipple, McLeod, Kooks, & MUCH MORE..) Boostaddict Lethal Performance 2 09-08-2015 09:56 PM
AM or Bama please comment whatsup62 5.0L GT S550 Tech 1 09-03-2015 01:38 PM
Video - 2015 Steeda Mustang Product Testing (Prototype Suspension Parts) [email protected] Steeda Autosports 0 09-01-2015 08:16 PM
40l, bama, results, track
Featured Sponsors
