What can i do with 2Gs
Hey ive put about 10k miles on my 06 V6 and am looking to add a little bit of power under the hood. My goal is to have a 13.5 second car will $2,000 do the trick? thats kinda what im working with atm. What would you guys reccomend? Thanks a lot.
RE: What can i do with 2Gs
To get to 13.5 is really going to take a power adder... for your $2000 budget the only option would be N20.... going to probably take the 100 HP shot to get to 13.5... To get a safe N20 setup that is track ready you'll probably spend close to $1000. To run the 100HP you'll also need a tuner like the SCT X-Cal2... and a custom tune to retard the timing (-2 degrees)... the tuner alone is about $400.. More than likely you get wheel hop so you'll want to put in some rear lower control arms... looking at just over $100 there.. probably want some type of Limited Slip Differntial too... so you'll be very close to or a little over your $2000...
H0SS302
02-10-2008 02:10 PM
