Intake Manifold
Intake Manifold
Does anyone make an aftermarket intake manifold or are ours just not that bad stock? also if they are unavailable maybe any tricks to get it to flow better air .. i will be installing a new throttle body and heads from supersix motorsports and i want somethin that will keep up with the flow of all the new units .. i plan on also supercharging in the near future
RE: Intake Manifold
Don't count on it, most of the big mods go to the GT. If you want to open up the airways then you'll have to get it done yourself. But their are heads and cams for our stangs but i wouldn't do business with them after an incident somebody else had with them. SSM that is
RE: Intake Manifold
Explorer Express could probably fab up a better intake for NA cars if they were inclined. You can get some regrinds from Crane for the cams, you can get the pistons from wiseco, that is what SSM does. As far as heads and the block, you can have any machine shop do it for you. SSM is one of the shops that has a relationship with an engine builder. Delk is another shop and I'm sure all the top shops have relationships to help you out.
RE: Intake Manifold
ORIGINAL: rygenstormlocke
RE: Intake Manifold
ORIGINAL: hoshua2582
so whats so bad about SSM?? they screw one of y'all over or somethin?
Actually, its a matter that is between SSM and one of their customers (its not a public matter). Outside of that, there are individuals happy with SSM and they have a strong following in the 3.8 world. Are there alternatives? Yes. So do some research, do the math and go with what works best for you.
RE: Intake Manifold
thanks for the tip on that then rygen ... im not wild about spending that much money on heads as it is ... if you know of anyone else i would really appreciate the input but i sure know that im stuck in this car loan for a while (good enough credit to get the car but not enough to get a GT)
so i wanna get the most power out of it ... thanks for everyones input on this situation
daltron
04-28-2016 08:10 PM
