JBA wires - need cylinder order
RE: JBA wires - need cylinder order
The easiest way to install plug wires is to remove them carefully one at a time. Match the removed wire to the replacement wire of thenearest length (replacement wire is usually the same length or just slightly longer). Install it and then remove the next wire, match it to areplacement wire, install, and then repeat.
Do not remove more than one wire at a time oryou may become confused.
