Stock 1/4 mile times??
RE: Stock 1/4 mile times??
1st, what was ur 60ft time? 2nd, When did u floor ur car? 3rd, did u spin the tires off the line? 4, R u on stock tires(not aftermarket ones the same size)? What was the temp. outside the day u ran? How many miles r on ur car? reply to this and u will get lots of help!
Sorry to say the track i go to doesnt have time slips they just give u ur 1/4 time, I floored it just after green, i didnt spin much maybe a lil, the temp had to b mid 70's and i got about 30k on it.
I believe Boss244, the fastest N/A-bolt on 4.0 needed to change hisfuel filter, plugs, and switched to mobil 1 sythetics.After he changed those he picked up3 tenths. Maybe run fuel injector cleaner in thecar a week before u go too.The spinning off the linewill make u lose a couple to a few tenths too.Instead of flooring it off the line, rev the car up to 1.5-2k rpm and have ur foot on the brake. Then when it turns green. Let off the brake and floor it slower.So just bydoing thatand learning how to launch u should easily see15.7's or 15.8's. That should help a lot. Good Luck!
take your TCS off
Take some psi out of the rear tires and put some in the front.( i ran 29 in the back and 40 in the front)
turn off AC
Roll up windows
Get a good reaction time
dont floor it right away, get going then floor it
i ran a 15.399 with my car and it was pretty much stock, just Axle back and a tunless CAI. the next time i went i just got better with my reaction time and ran a 15.332. it takes time to get good at the track. the more you go the better you will get.
turn off AC
Roll up windows
ORIGINAL: Dwisforme05
take your TCS off
turn off AC
Roll up windows
take your TCS off
turn off AC
Roll up windows
To the OP, another consideration is that not all tracks are created equal. There are MANY factors which come into play. Just don't get discouraged - go again, and go often. Drag racing is exciting and frustrating at times, but most of all it's FUN.
