3.73 gears
I want to get 3.73 gears for my 07 v6 mustang. I was woundering were the best place to get them from and aproc how much intall. thanks
RE: 3.73 gears
v6mustangstuff.com
americanmuscle.com has em as well, what are your plans for the car? you could benifit more from 4.10s, you will also need a bering kit
you also should get an LSD, again depends on your plans for the car and how you drive it, ideal set up 3.73 http://www.americanmuscle.com/mopepl3gefor.html 4.10 http://www.americanmuscle.com/v6gears.html bering kit http://www.americanmuscle.com/rearendrebuild1.html Detroit true trac LSD, reason i recomend this is cause i personally have blown up 2 7.5" ford diffs with a pretty much stock auto 3.8, (same rear end) http://www.drivetrainspecialists.com...ruetrac-1.html |
Seriously I went thru the same thinking when I wanted gears & posi in my V6 Mustang. This is a mod that going to cost somewhere between $900.00 and $1500.00 for all the parts and install. Gears are $200-$300, posi unit is $200-$500, bearing kit is about $100.00 and install is going to set you back $400-$600. newtakeoff.com has an 8.8 w/3.73s for $880.00 plus shipping(mine was $165.00 to my door!) This is a very easy install, you end up with a much beefier rear and no whine. Think about it.
Originally Posted by my first mustang
(Post 5359486)
built 7.5 > stock 8.8 |
(Post 5359486)
Nino has the gears and diff for $440 shipped. Any decent speed shop can do the install for $250-300 at most. If you shop around, you can be rolling with a solid install for around $600. |
