Transmission swap ?
RE: Transmission swap ?
ORIGINAL: MN Moose
Actually the guy on the collec-tive that is doing the swap is still in the process. And he got everything INCLUDING the tranny for under $500.
So $500 for a manual tranny swap does not seem unreasonable to me.
ORIGINAL: SteelStang05
Guy did a swap like this on 4.0 collective forums, still cost him over $2.5k I thinkand I think he installed the parts himself.
i could understand the reasoning from going auto to manual but manny to auto sounds like a better reason to get a second car for your commutes. also, you'll save some wear & tear on your stang. JMO.
yeah, dont sacrifice your stang for daily traffic reasons. If an auto stang is what you want ANYWAYS, then do what you gotta do. i love my auto but daily grind traffic jams wasnt the reasoni chose it. i like cruising and stomping without f***ing around with pushing clutches and shifting gears. maybe when i get a gt500, then i'll love the manny again [8D].
what are you referring to when you say custom fabbing? There is no fabrication involved. Like i said its a basic swap once you have everything, and there really isn't too much to get. I have a second car so a rental would not be needed. And this swap would probably take two days max if i have everything the day i start.
I don't know how mechanically inclined other people are around here, but this is a lot simpler than the 3.73 gears and tlok that i just installed over christmas break. Just my opinion though.
ORIGINAL: MN Moose
ORIGINAL: MN Moose
ORIGINAL: MN Moose
I see, I was thinking that custom fabbing could be the clutch pedal, tranmission(not sure if their a direct fit and replacement with each other), andstick shifter/auto shifter(factory created is different from aftermarket switched). I also forgot which you mentioned, you may need to rent or borrow parts which could be costly or hard. I was just suggesting to look at your options. With what your saying is, I can see it would cost you about the same money to sell and buy a stick car as it would to do the swap if you install everything yourself(most likely $600-$1k). The difference is, would you want the headache of test driving and talking to other people or working a bunch of hrsin the driveway for2 days?Good Luck with whatever!
ORIGINAL: z06stang
Jake, are you thinking on doing the 4.6 and manual swap all at once? thats the vibe i'm kinda getting from you. if so cool especially with Brad finishing up the trans swap and all the others doing the motor swaps.
and i got the FRPP gears and tlok. I got them used to the gears were already broken in and there is a little whine @ 35 mph and 55 mph. It is no where near what i thought it was going to sound like, i can barely hear it.
steelstang, i see your points, but i have already heavily looked into the auto to manual swap and I KNOW for a fact i could do it for under $500. The reason i would do this and not trade in my car for another one is: i like my current set up, i like everything i've already done to my car, and most of all i enjoy working on it. I've done all the work on it myself (exhaust, headers, rear end, stripes, axle housing, and even the simple stuff) i dont know if you take your car to the shop to get everything done but i personally prefer to save myself money and i like doing it.
