does 2008 pony pakge come with t lok already?????
im thinking about gettin new gears but evrywhere i read everyone says if u get gears to get a t lok as well. but i think my car comes with t lok already. i read in the manual and it says that traction lok is available if equipped.. so its an option. i got the pony pckage premium with all the extras so im guessin i might have t lok...i have the TCS which as an option too. buti dont know where to look to find out if i have it.??? and if i do does that mean i dont need one or still should get a differnt one. or will the stock do.??? 2008 V6
RE: does 2008 pony pakge come with t lok already?????
As someone else said in your other post.. Find an open street on a cold day and floor it. If you get 2 tire tracks, then you have a Tlok. If you see only 1, then you don't have a Tlok.
Fixed...
ORIGINAL: noober
As someone else said in your other post.. Find an open street on a cold day and floor it with the TCS off. If you get 2 tire tracks, then you have a Tlok. If you see only 1, then you don't have a Tlok.
jack the rear end up, put it in neutral, spiin a tire, if the other one goes in the same direction its LSD, if it goes the opposite, its open
ill garentee it doesnt have one straight from ford, there would be to much warrenty work
Pony package does not come with a Tlok - I can guarantee that since I've had work done on my rear gears.
If you have traction control there is a "TCS" button above your radio to the right. If you don't have that button to turn it on or off, then you don't have TCS. TCS has nothing to do with the Tlok though - completely different systems.
ORIGINAL: 28HopUp
Fixed...
Fixed...
ORIGINAL: noober
I don't even have TCS. ^_^
