x-cal 3 from bamachips
hi i just recieive my bamachip c&l and x-cal3 the tune are great i havn'e install the race tune justyet is there a real differencfe between the performance andthe race tunes also when i got the xcal i see something that connet to the ports on the side and bottomany of the guys recieve anything elsewith the programmer. usb connection?
RE: x-cal 3 from bamachips
Don't really understand to OP's post, some punctuation would be helpful. Torque tunes make more power in the lower-RPM range, performance is a good all-around tune, Race is more power througout the entire RPM range. One could say the torque tune maybe gives you a little bit more jump off the line, while the race tune gives you more high-end
The USB (Universal Serial Bus) connector is used when you connect from your computer directly to your tuner, to be able to download tunes. It is not needed when you load tunes to your car, it is only used when you get custom tunes from a vendor. I hope this clears up any issues you have with the USB port on your tuner.
ORIGINAL: basketballord
I would just load 91 RACE [sm=smiley20.gif]
blazen351
04-22-2006 09:50 PM
BRENSPEED
08-26-2005 02:26 PM
BRENSPEED
08-15-2005 07:37 PM
