anyone who has put on 8.8 rear need info??????
Old 03-19-2008, 11:18 PM
tamazulense
tamazulense's Avatar
Default anyone who has put on 8.8 rear need info??????
okay im definitly going to put on some new gears and diff lock. but now im thinking of just buying a new takeoff 8.8 with 4.10s and the diff lock. but i need info from people who have done this. is it worth paying the 300-450 more? and can u feel the extra wieght cause this is my main problem in gettint it. i know ull probably say to get itif thinking of going the vortehc or supercharger way...and i am in about a year. but our 7.5 will hold up. so is it worth getting the whol 8.8 rear end????
tamazulense is offline
Old 03-19-2008, 11:48 PM
danbevsv6rumbler
danbevsv6rumbler's Avatar
Default RE: anyone who has put on 8.8 rear need info??????
well... i have an 8.8 that I'm in the process of getting ready to place on my v6 here within the next couple of weeks. i got my takeoff with 3.55 gears and 15K miles on it for $225 locally (good deal, I hope). If you're willing to wait a bit I'll give you all of my impressions once I perform the swap the last week of march.
can anyone else chime in?
danbevsv6rumbler is offline
Old 03-20-2008, 11:24 AM
157dB
Cut & Paste Expert
157dB's Avatar
OK, if you go with the heavier 8.8 you need the right GT springs
and shocks or wheel hop will be out of this world. If you go
aftermarket springs, get em for the GT springs and not the
V6 springs for the rears. Its the unsprung weight, not the
sprung weight that is different with the 8.8 VS the 7.5.
Also get the 8.8 that has the V6 Pinion Flange.
Its totally worth it for the T-Loc, gears and heavier axles
with more splines.
157dB is offline
Old 03-21-2008, 12:17 AM
tamazulense
what do u mean wheel hop? i had the impresion that the 8.8 was a straight bolt on except for the new pinion flangewhich is only like 45 bucks.
Old 03-21-2008, 12:31 AM
fazm
fazm's Avatar
ORIGINAL: 157db
with more splines.
what are you talkin bout? i run stock springs/shocks in the rear, and have zero wheel hop.
im pretty sure they are even the same springs for v6/gt in the rear, and possibley even the shocks.
fazm is offline
Old 03-21-2008, 12:36 AM
danbevsv6rumbler
go to fordparts.com
and search for the part in their OEM catalog.
Part # E9TZ-4851-A
i got the pinion flange for $28+$10 shipping
I would have thought that the since the axle is part of the suspension whole rear linkage system that the v6 springs would be just fine since the weight of the car is pushing against the axle and not the other way around...
EDIT:
according to the website i posted above apparently the rear coil springs are the same for both models (v6 and GT) - it's the shock absorber that is different - possibly because the gt is heavier and had suspension set up a little more aggresively?
Old 03-21-2008, 12:37 AM
SeanoStang
SeanoStang's Avatar
i was thinking about going this same route
SeanoStang is offline
Old 03-21-2008, 12:51 AM
tamazulense
so 157db is totally wrong about the whole GTsprings. cause that kind of put down the 8.8 rear buy i had in mind. cause if i have to spend more money on springs i wont do it. the rear end is already 900 bucks. so it is just a srtaight bolt on right. no other parts neede except for pinion flange.
Old 03-21-2008, 01:04 AM
tamazulense
hey famz u have the 8.8 rear. and if u do is it really worth it over just gears and t lock in 7.5 rear.
Old 03-21-2008, 01:08 AM
fazm
fazm's Avatar
yes i have the 8.8 rear
worth it? of course
i broke an axle in the 7.5
broke the tlok and jacked the bearings, snapped a control arm with the stock 8.8
now i have a truetrac differential in the 8.8
if you plan on any kind of f/i id go with an 8.8. even at that, with the 7.5 i broke the axle while n/a. im a bit more agressive launching than most lol
fazm is offline
Quick Reply: anyone who has put on 8.8 rear need info??????
