Zabteck TB
RE: Zabteck TB
Not sure if this is true or not, but I've read before that throttle bodies don't really serve a purpose as far as adding HP. Thinking about it, it kinda makes sense since aside from adding "turbulance" to the air, you're still getting the same amount and volume of air into the engine.
RE: Zabteck TB
ORIGINAL: bronxbomba63
RE: Zabteck TB
I like the idea of the Zabteck because it's a remachined factory piece which means it will function properly unlike some of the aftermarket TB's. Also the change out to a larger low profile butterfly and the shaft and screws are all flush to decrease turbulance and increase flow also.
maxshuty
08-23-2014 10:29 AM
