3.73 gears
Old 11-27-2007, 12:59 PM
WeMowMuppets
WeMowMuppets's Avatar
Default 3.73 gears
I want to get 3.73 gears for my 07 v6 mustang. I was woundering were the best place to get them from and aproc how much intall. thanks
WeMowMuppets is offline
Old 11-27-2007, 01:07 PM
Sancho805
Sancho805's Avatar
Default RE: 3.73 gears
v6mustangstuff.com
Sancho805 is offline
Old 08-17-2008, 01:51 PM
mustangman02232
mustangman02232's Avatar
americanmuscle.com has em as well, what are your plans for the car? you could benifit more from 4.10s, you will also need a bering kit
you also should get an LSD, again depends on your plans for the car and how you drive it,
ideal set up
3.73
http://www.americanmuscle.com/mopepl3gefor.html
4.10
http://www.americanmuscle.com/v6gears.html
bering kit
http://www.americanmuscle.com/rearendrebuild1.html
Detroit true trac LSD, reason i recomend this is cause i personally have blown up 2 7.5" ford diffs with a pretty much stock auto 3.8, (same rear end)
http://www.drivetrainspecialists.com...ruetrac-1.html
mustangman02232 is offline
Old 08-18-2008, 12:28 AM
my first mustang
my first mustang's Avatar
Seriously I went thru the same thinking when I wanted gears & posi in my V6 Mustang. This is a mod that going to cost somewhere between $900.00 and $1500.00 for all the parts and install. Gears are $200-$300, posi unit is $200-$500, bearing kit is about $100.00 and install is going to set you back $400-$600. newtakeoff.com has an 8.8 w/3.73s for $880.00 plus shipping(mine was $165.00 to my door!) This is a very easy install, you end up with a much beefier rear and no whine. Think about it.
my first mustang is offline
Old 08-18-2008, 01:18 AM
mustangman02232
you shouldnt have whine even if you swap out stockers if the shop you go to can do it right
built 7.5 > stock 8.8
Old 08-18-2008, 08:53 AM
illin
illin's Avatar
Those prices are really high IMO.
Nino has the gears and diff for $440 shipped. Any decent speed shop can do the install for $250-300 at most.
If you shop around, you can be rolling with a solid install for around $600.
illin is offline
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: 3.73 gears
