What oil/filter do you use?
#31
As far as oil change frequency, many many people change their oil too early. But other than just wasting money, it doesn't hurt. Oil change frequencies are not balck-and-white as each persons driving habits plus your environment will require you to adjust accordingly. But typical rules of thumb are:
- Dino oil - every 3,000 miles or 6 months
- Synthetic blend - every 5,000-7,500 miles or every 6 months
- Full synthetic - every 8,000-15,000 miles or every year
I've followed that methodology for over 30 years. Irregardless of dino, blend or full syn, every engine I had ran just as well up to and beyond 200,000 miles. Just be sure to use a decent oil filter at each oil change. And doing it yourself is easy, helps you bond with your car and saves time and $$.
#33
#34
I've used Penzoil forever, never had a problem, and change the filter every time. I use a little trick a friend told me about. I change the oil every 3,333 miles. (13,3333-16,6666-20,000-23,333 and so on) That way I never have to write it down and I never forget.
#35
Mobil 1 full synthetic, change every 10K and could go 15K. Independent lab report 5 years ago, says Dino oil does not begin to break down until 6K normal driving conditions. Use Tier 1 gasoline and still get 28+mpg hwy with 106K miles. Usually Shell 87 for both our cars.
My 2 cents
My 2 cents
69MustangCoupe393cid
07-09-2015 12:13 PM
