Gt front bumper on v6
I have a pretty beat up front bumper on my v6 and was looking into putting a take of gt bumper on because I like the look of them better. My car already has gt fog lights and i know the grill will be different but I am unsure if the gt bumper will bolt up to the v6 body.
Thanks
Thanks
well...almost
you will still need the fender liners on each side if you want to do it right...
the styrofoam pieces that go under the gt bumper are optional as is the radiator stone deflector.
now the wiring to the fogs is something else...unless you have the pony package, then its simple...
well...almost
as well as the asthetics of it...
My foam saved me from a lot of unneeded damage.
The damage would have been frame and body instead
of just the bumper cover/styrofoam getting damaged...
well the v6 styrofoam is actually bigger than the gt styrofoam, thats the reason folks consider it optional... because you can actually sand down the v6 styrofoam a bit and it works fine for the gt bumper.
i wouldnt know, because i spent the 5-10 bucks to install the gt styrofoam and case closed...
'TRIM' the V6 foam for the GT bumper... :P
Highly detailed pics as well...
The forum also has a fine Search Feature thats
just begging to be used, as its mighty lonely...
