Auto Headlights
Old 11-19-2010, 05:52 PM
drakefamily2
drakefamily2's Avatar
Default Auto Headlights
I have a 06 and was wondering if anybody knows if you can do any wiring to make the headlights come on when you start the car. I have a 07 impala and the headlights have a auto position when you start the car, nice feature. That way you don't have to worry about daytime running lights.
drakefamily2 is offline
Old 11-19-2010, 06:50 PM
obxdude018
obxdude018's Avatar
That is a gm thing with the auto headlights, the only thing I could think of is to first figure out the amps that the lights use, find another component that turns on when the engine is started and rewiring it to that component and then increase the fuse to accomodate the extra draw, but in all opinion it's not worth it, if you change the stuff around and it's not done correctly you could fry something that is really important.
obxdude018 is offline
Old 11-19-2010, 08:18 PM
Whitehorse10
Whitehorse10's Avatar
Given that the 2010 and later models have automatic headlamps you should be able to convert yours using Ford parts.
Whitehorse10 is offline
Old 11-19-2010, 09:01 PM
157dB
Cut & Paste Expert
157dB's Avatar
ElWrongO.
Ford software, maybe.
Its a software thing, not a hardware thing.
Are we talking daytime running lights or
full on 100% low beam during the day.
The latter can be accomplished by placing
a normally closed relay in the headlight wire
and have it open the headlight circuit when
the ignition is on. Simple pimple.
Tan/white wire on the back of the headlight switch.
Hook the relays coil to the accessory delay
available in the SJB in the pass side kick panel.
157dB is offline
Old 11-20-2010, 12:15 AM
Whitehorse10
Originally Posted by 157dB
ElWrongO.
LOL yeah, there's no way that anything from a 2010 V6 could be converted to fit an 06 because the cars are completely different. Whatever.
Old 11-20-2010, 08:02 AM
drakefamily2
I was talking full on headlights. If it is full on you never have to remember to turn them on when its raining or foggy in the daytime.
Old 11-20-2010, 11:55 AM
157dB
Cut & Paste Expert
157dB's Avatar
This can easily be accomplished by placing
The headlight switch makes a circuit to ground to turn OFF the
headlights and unmakes that same circuit to ground to turn
ON the headlights.
Reversed Logic of sorts.
If the switch goes bad, the headlights default to being on.
Thats better than them not coming on when the switch breaks.
157dB is offline
Old 11-20-2010, 06:10 PM
drakefamily2
Thanks for info.
Old 10-23-2012, 03:32 PM
drakefamily2
I added a pony grille with fog lights, had to disconnect the above wire to get the fogs to work with factory headlight switch. Any way to get my daytime running lights to work again.
Old 10-26-2012, 11:05 AM
157dB
Cut & Paste Expert
157dB's Avatar
It depends on how you wired the fog lights.
Did you use a GT headlight switch?
Attached Thumbnails Auto Headlights-headlight.jpg   Auto Headlights-img_2985.jpg
157dB is offline
Quick Reply: Auto Headlights
