06 mustang passanger parking lights and tail lights stay on!!
well it was rainning lik crazy here in LA, CA. and i found my car lights were on only on the passanger parking lights and the tail lights on.. i checked the switch. i made sure everything was off. and it was. so i took the battery out and put it bak in and still the same shizzz... i checked my tuner and no problems found.. plz help!
Sounds like the infamous waterleak issue. Check the passenger carpet by the kick panel. There's a TSB for a water leak which causes corrosion of the SJB (Smart Junction Box). It's very common in the 05's and 06's and there's a "bandaid" that Ford used for the 07's. Not a pretty problem...
Let us know what you find.
Mine lit the same lights when I had water in the SJB. I sealed everything according to the TSB and removed the SJB to dry it and clean it.
Here's the TSB for it.
http://www.stangpit.com/wp-content/i...b/08-26-07.pdf
inyadreems
08-21-2015 09:10 AM
