Brake Upgrade....Couple of questions.
I am planning on upgrading to GT brakes.
The parts that I need are......what just the rotors and the caliper brackets?
I was going to just pick up some caliper brackets from a wrecked S197 and buy some upgraded rotors to complement them....
Any help would be appreciated
Thanks guys!
Thanks guys!
If the 2010-11 is like the 2005-2009 then all you need is the rotors and the brackets for the calipers.
For some reason though I thought that the 2010-11 had the same size brakes up front? If they are different sizes though then it should be just like swapping the 2005-09
I'm almost certain they don't.....now I may be wrong....but I'm almost certain that they didn't put the 12.4's in until '11.
If that is the case then EXCELLENT, I can just upgrade rotors and pads.
If not, then I'd like to upgrade a bit for now and Hopefully find some brackets cheap somewhere.
Found thisi kit!
Pretty stoked Gonna go ahead and order soon!
http://www.cjponyparts.com/front-dis...2010/p/M2300D/
Hate to be a party pooper, but I did the GT brake upgrade with some Hawk pads and wasn't all that impressed... Gonna go with slotted next time. The larger front rotors do look better than the 11.5"
I'll be buying slotted rotors for it after I get the brackets
I used this kit: http://www.mossmuscle.com/Shop/ViewP...eIndexID=72228
Yeah I upgraded to 18's and the GT brakes give more clearance too. I also needed new brakes so it worked out.
