intermittent sputtering at idle
While letting the car idle, if I go and listen to the exhaust it seems to sputter every so many seconds or so, almost like its timed. Sitting inside the car i can feel it from the exhaust vibration everytime the sputter occurs, I get a like a surge through the exhaust. Other than that, the car runs fine. I am thinking its the sparkplugs, but wouldn't i feel it all the time and not just idling? Any input will be appreciated.
P.S.
The fuel filter was changed 4k miles ago
I cleaned the throttle body, and followed the manual on re-learning the idle.
Sparkplugs were changed about a year ago(10-15k miles or so) they are Bosch (when i bought them I had no idea that they dont always run right in our engines with the waste spark used), so I am thinking that's the cause of the problem, but the car runs fine when not idling.
P.S.
I was really hoping for a cure lol as it is rather annoying, I guess if no one chimes in with one I will just set my idle higher with my tuner. Should change to Autolites anyways instead of Boschs?
I'm running autolite 5143's and mine still does it, but I have a supercharger too. So I don't know if that makes a difference?
Ahh man, I really hope this is not the nature of the beast..... I dont think your supercharger would do that, if anything I always thought one would make it idle better. But then again I'm not an expert at superchargers by any means.
I'd run 1 or 2 tanks of SeaFoam or Techron first to see if it's a simple fuel system cleaning that's required. Always try the simple things before replacing hardware.
Well im a big believer of "getting what you pay for" saying, so figured the bosch would be a better plug, but that's apparently not always the case.
I dont have CAI, just stock, after checking today everything seems to be pretty tight.
