Just got seafoam, is this correct? - Page 2 - MustangForums.com
Old 02-03-2012, 05:45 PM
CoupeKiller
CoupeKiller's Avatar
Originally Posted by Nuke View Post
similar to how much quicker my car is when she's freshly washed and polished.
LOL, I think we all feel that way when they are clean. I swear I go 0-60 in like 3 seconds when it's clean..and get better gas mileage because less dirt means less drag lmao.
so, mine has 48K miles on it...and pulling the carfax it was a rental car before I owned it. think I should seafoam mine as well since I'm SURE it's never been done.
CoupeKiller is offline
Old 02-03-2012, 05:47 PM
CoupeKiller
^^ that was a question by the way
it's kinda hard to have additives put in the tank since I have the "capless" fuel tank and it requires you press in the side buttons at the opening..and they are a B**** to push in while trying to add something to the tank..
Old 02-03-2012, 07:02 PM
Nuke
Nuke's Avatar
I've used some type of fuel system cleaner on every car I've owned since about 1980. Seafoam is a good product and one of the few additives that I dare to use on the Stang. Techron is what I use typically unless I suspect an issue, then I Seafoam.
Nuke is offline
Old 02-04-2012, 06:21 AM
Boneman
Boneman's Avatar
Seafoam itself does not improve performance as it seems a few above have implied. SeaFoam will remove crud and carbon buildup which hampers performance.
+1
It does not ENHANCE performance... as much as it RESTORES performance. It gets the carbon outta the way. In fact, I've recommended it to friends that have failed inspection for NOX, etc. As their engines have carboned up considerably.... run a tank of seafoam and they pass.
It does work.
Boneman is offline
Old 02-25-2012, 05:31 PM
jdphillips73
jdphillips73's Avatar
i use lucas upper cylinder lub in my wifes car, my truck, and the stang... at least for the past year
I used seafoam in my old f150 a few years ago...
so my question is... lucas requires 3 oz per fill up and seafoam would require 16oz in a stang... are these the same type products?
jdphillips73 is offline
Old 03-12-2012, 02:49 PM
kevinmalec
kevinmalec's Avatar
I also use the Techron gas treatment every 5k miles or so. I also fill up with Chevron 93 octane gas.
kevinmalec is offline
Old 03-13-2012, 07:23 AM
Boneman
Boneman's Avatar
Upper Cyl. Lube would be the operating words here. Not so much a De-Carboning agent as... well.... as it's described a lubricant. Probably more similar to "Marvel Mystery Oil"... which is also an lubricant.
Another product that motorcyclists would know more about would be Yamaha "Ring Free".... similar to Techron and very effective.
Boneman is offline
Old 03-13-2012, 09:34 PM
baddog671
I put a bottle of Gumout in the gas tank every oil change (8k), since I got 4 or 5 for free.
I used a bottle of Seafoam around 30k, but I used IV-dripped it through the brake booster line.
baddog671 is offline
Old 03-23-2012, 08:29 PM
NyghtSpydr
NyghtSpydr's Avatar
I just tried SeaFoam on my 2010 V6, it has 36k miles on it, used to be a rental car...so I am sure no one ever ran SeaFoam through it. Is there anything else I should do to help restore some of the lost power?
I also hear I can run a full can of SeaFoam in my Oil reservoir, is this correct?
NyghtSpydr is offline
Old 03-24-2012, 10:17 AM
157dB
Cut & Paste Expert
157dB's Avatar
Originally Posted by GCCBrian View Post
Just got seafoam, I plan on putting it into my gas tank while it's on when the car is halfway between empty and a quarter. I'll let it sit for 10minutes, turn it on and let it sit at idle and have the smoke clear on its own, then drive it, til the smoke goes away, and fill the gas full.
That a good way to do it?
With the saddle bag style fuel tank the S197 has, it is not.
Your fuel could get over diluted with the sea-foam.
Follow the directions on the label.
BTW ^^^ Do not put any into your "oil reservoir".
157dB is offline
Quick Reply: Just got seafoam, is this correct?
Featured Sponsors
