Rear gear question
Old 02-11-2012, 10:45 PM
CoupeKiller
CoupeKiller's Avatar
Default Rear gear question
so I'm looking for my gears now..I've decided on 3.73's with the ford racing TLOK system. question is, since I'm replacing the gears do I have to also purchase this?
http://www.americanmuscle.com/rearendrebuild1.html
CoupeKiller is offline
Old 02-11-2012, 10:52 PM
obxdude018
obxdude018's Avatar
If you are replacing the differential then yes plus you want to make sure everything in there is brand new, would hate for a bearing to give out a 1000 miles after the new parts were installed. I would highly recommend first however to try and find a 8.8 rearend instead of using the 7.5, I just found one for $350 with 4.10's. You will spend around 7-800 for the parts and install unless you can do the work yourself. I am first hand advice on this, I built my 7.5 and now it has a gear whine and ever since I regret not just getting an 8.8.
obxdude018 is offline
Old 02-12-2012, 08:20 AM
Moderator
JimC's Avatar
Worst modding decision I ever made was trying to build the 7.5. I broke it with Richmond gears and the LPW girdle to strengthen it and only had a set of drag radials and tune at the time.
It cost me more to build the 7.5 than it cost to buy the 8.8 and swap it in
JimC is offline
JonnyBlazeGT
11-03-2015 01:10 AM
GimpyHSHS
08-29-2015 06:30 PM
inyadreems
08-21-2015 09:10 AM
69FB
08-18-2015 08:50 PM
Mnuckolls
08-09-2015 08:54 AM
Quick Reply: Rear gear question
