Bleeding the clutch slave cylinders
Well - That was helpful - Did a search before posting this & didn’t find much info so I will burp the release cylinder bearing before installation. All of the lines seem to be vertical leading up to the master cylinder so I guess all of the bubbles will self evacuate over time. I will slowly depress the clutch pedal multiple times & try to help some of the air out.
Just replaced my flywheel, disk, pressure plate & release bearing cylinder. If anyone wants to chime in with a better suggestion, it would be appreciated.
Since there is no bleeder valve the recommended procedure is to apply vacuum at the reservoir. If I remember correctly you apply the vacuum and hold it for 1 minute before releasing it slowly. You use a . If it doesn't have a cap that will cover the fill opening you will have to use a spare cap or a pies of rubber that you can hold down and seal it the opening while you apply the vacuum.
People have had success parking on ramps or a steep incline and doing the slow depress & release routine. There are discussion threads on this so you might retry the search as well.
Since there is no bleeder valve the recommended procedure is to apply vacuum at the reservoir. If I remember correctly you apply the vacuum and hold it for 1 minute before releasing it slowly. You use a hand pump like this one. If it doesn't have a cap that will cover the fill opening you will have to use a spare cap or a pies of rubber that you can hold down and seal it the opening while you apply the vacuum.
Applying a vacuum is a very good idea - I would not have thought of it - It will definitely pull some of the air out. Parking on an incline or jacking up the front of the vehicle is smart too. I'll try doing another search / worded differently to see if any other info is available.
Thanks for responding
junior04
09-28-2015 10:53 AM
