Clutch Bushings - 2005 Mustang V6
I've got a 2005 V6. The bushings for my clutch and brake pedals are shot. Talking to Ford, they don't sell them and I have to buy the entire pedal assembly ($280.00).
Does anyone know a source for just the bushings?
Thanks,
Ryan
Thanks,
Ryan
I got a new clutch at 55k because the slave cylinder went and it wasn't too much more to get a new clutch. Since then I've got this intermitent issue where after driving on the highway for 15 or so miles the clutch is about 4 times harder to push in. The place that did the clutch replaced the master cylinder last time and that fixed it, but Luk won't replace it again unless the bushing is replaced first. Trying to find a way to not spend $280 on a bushing.
Wow.... that a slave cyl went at 55k is a bit disturbing.... And I've never heard of the pedal bushing failing before. I've 135K on mine and (touch wood) not had either of those issues.
+1 on finding a lightly used unit. $280 for the assembly though.... I've seen much worse prices on simpler items than that.
My slave cylinder/throw out bearing went out at 65K miles. I had to replace out most of the clutch assembly, except for the master cylinder. I replaced out the slave cylinder, throw out bearing, fly wheel, revised pressure plate and etc.
So.... yeah, 133K on the original.
Of course... I'm of the school that "every time you use that clutch is one less time you get to use it." Hence, if I think of it and am not under any pressure to accelerate quickly, I shift sans clutching.
'stangdude
08-12-2015 01:27 PM
