Would this system work to convert my v6 pony to a true dual exhaust?
Old 08-18-2012, 12:41 AM
2K6V6PONY
2K6V6PONY's Avatar
Default V6 Dual exhaust installation
Just to be sure I get the right clamps I want to know what you used where the x-pipe meets the down pipe with the cats. I found a dynomax manual showing that the x-pipe should use 2 1/4" there and 2 1/2" where the
Originally Posted by akdoggie
You have to cut the y pipe on your original exhaust, (allow enough extra pipe to make sure you get a good seal when you cut it) but you have to do that will all the add on systems. Remember, Measure twice, cut once. You don't need an expensive mistake.
I used the 2 regular clamps on the clamping to the header pipes and the band clamps where the intermediate pipes hook to the xpipe.
2K6V6PONY is offline
Old 08-18-2012, 12:44 AM
2K6V6PONY
2K6V6PONY's Avatar
I found a dynomax installation guide for the X-Pipe you recommended to use for the conversion. It specifies that where the downpipe\catalytic converters meet the X-Pipe to use 2 1/4" band clamps. You say that 2 1/2" worked fine for you?
http://www.google.com/url?sa=t&rct=j...M2uLg18gG2c2MA
Old 08-18-2012, 09:56 AM
157dB
Cut & Paste Expert
157dB's Avatar
Amazon says it will so you are backed with a return guarantee if it does not fit...
AMAZON:
This product fits your 2007 Ford Mustang
Trim: Base
Engine: 4.0L V6 Gas SOHC Distributorless Naturally Aspirated SFI Electronic FI MFI
Note: Stainless Steel Cat-Back Exhaust System; 2.5 in. Dual System; Dual Split Rear Exit; Incl. Ultra Flo(TM) Welded Muffler; 3.5 in. Polished Stainless Steel Tips; 50 State Legal;
157dB is offline
Old 08-20-2012, 02:08 AM
akdoggie
akdoggie's Avatar
Sorry to no get back. Been ill. You are right. Follow the sheet from Dynamax. Remember I did this earlier so my memory may not be 100%. Enjoy your new exhaust. I did and still enjoy the nice rumble.
akdoggie is offline
Old 08-21-2012, 08:04 PM
2K6V6PONY
2K6V6PONY's Avatar
No problem at all. Sorry you've been ill. Hope you get feeling better soon bud. As for the dual exhaust conversion my x-pipe and the rest of my parts should arrive tomorrow. I will be sure to take lots of pictures. :P
b8checker
10-08-2015 12:55 PM
folivier
10-02-2015 05:34 AM
09-30-2015 12:39 PM
b8checker
09-30-2015 07:11 AM
09-24-2015 09:18 PM
Quick Reply: Would this system work to convert my v6 pony to a true dual exhaust?
