Manual trans fluid.... yeah, it's time....
Of late and particularly on hot days... duh.... like every farking day here in SW FL... the trans on the 05 has been getting quite balky. Well, today it got really balky this afternoon.... 97 degrees in the shade and I'm actually fighting to get the thing into 1st gear when stopped at a light.
Soooo... yeah kiddies, I don't think the fluid has ever been changed and there's 135K on the clock... so today, I stopped at AZO in search of the Amsoil stuff everyone seems to rave about....
Well, they don't have it... however they DID have Mobil 1 synthetic ATF... so I grabbed 3 quarts... gad, 10 bucks a quart no less.... glad I don't have to do this too often.
Have the process bookmarked already so that's good to go.... meanwhile, just wanted to post up a quick note about the forthcoming procedure pursuant to the aforementioned material.
I'm sure that the Mobil 1 is good stuff.... but then, better to hear from the gang here before I go dumping the stuff into the trans.
Anyone had any issues with the Mobil 1 ATF?
Thanks in advance for any and all insights.
I used Amsoil @ 35k, but I'm sure the Mobil1 will be just fine. Can't be any worse than the black sludge that's about to come out of your trans, right?
I see you live in the Cape. I live in Fort Myers last year, and my parents have a house in the Cape.
We shall see. As to engine oil... yeah, every 3K miles to be sure and always synthetic. I still find it bizarre to have auto trans fluid in a manual trans. WTF was so wrong with 90 weight gear oil anyhow?
I'm sure the new fluid will fix any issues.... as it only gets ugly when hot. Outta the driveway in the early AM and it's fine.
I'll have to keep an eye out for you Baddog. ;-)
Boneman, I know where a Amsoil dealer is in the cape. Drive south on del prado all the way down to cape coral parkway and take a right. There's a small autoshop on the right hand side of the street, from memory I'd say around a mile down. They had Amsoil stickers on the shop windows.
There's also a quicklube down on 46th & del prado called Superlube. Never go there
At this point in the game,
75W rear diff oil would be
your best and cheapest bet.
The damage has already gone
far beyond anything synthetic
ATF can fix..
Amsoil hand down.
Mobil is for the masses...
Big difference between the two besides the price....
My tranny was noisy last year. I put in RP front to back. Took a couple of weeks but the noise went away.
Also NEVER rest your hand on the stick shift and the aftermarket short shifters transmit more tranny noise into the car it sems.
Even the car manufacturers don't require 3,000 mile oil changes anymore (try reading your OM). The only business that perpetuates the 3,000 or 5,000 mile oil change is the Jiffy Lube and similar places.
It simply burns my britches when people insist that you need to change oil early or your car will pay the price.
Just changed mine at 75,000 using regular dex/merc. I had 3 quarts lying around so I thought at least new merc was better than old. I bought the car with 50,000 on it and I have no idea if it was changed before. It came out a darker shade of red, but not overly dark so I suspect it had a prior change. It has always shifted fine but I have an unusual problem with 1st when starting from a light I always hit after getting off the highway after about 50 miles of commuting. It starts out fine from the light, then seems to skip or lurch. For some reason, it only does it at this point in my commute. The change did nothing for the problem and, while I'll likely change over to Amsoil in the near future, I suspect the problem is not something it will resolve. Has anyone experienced a problem like this?
