Last edit by: IB Advertising
Browse all: Ford Mustang Powertrain Guides
- Ford Mustang V6 2005-2014: Why is My Car Losing Power?
Step by step instructions for do-it-yourself repairs.
lost power and shut off
P0106 - Manifold Absolute Pressure (MAP/BARO) Sensor Range/Performance
Description: MAP sensor input to the powertrain control module (PCM) is monitored and is not within the calibrated value.
Possible Causes:
Slow responding MAP sensor
Electrical circuit failure
Damaged MAP sensor
Diagnostic Aids: VREF voltage should be between 4.0 and 6.0 volts. The PID reading is in frequency.
GO to Pinpoint Test DM .
Possible Causes:
Damaged MAP sensor
DM15 specifically for MAP diagnostics.
Looks at least initially to me as an EGR issue. Exhaust Gas Recirculation System Module (ESM) not liking something.
http://iihs.net/fsm/?dir=221
I'm no mechanic, but I did sleep at a holiday inn express last night... Seriously though, doubt it's excessive fuel delivery, that's a symptom of the EGR issue if the fuel pressure is actually high, that's all.
They view the voltage difference from the 2 as the service manual states for the test? Can be just a leaking line going to it, etc..
that i don't know...we took it there because we know the mechanic, it's a small garage, does inspections and general repairs, told me it was above their capabilities after trying to replace the egr and maf sensors with no difference....it has to be towed back home, then maybe to a ford dealer at some point...
I'd at least attempt to DIY at this stage. Having the dealer hook it up to the VCM tool I'm sure will let them find it relatively quickly as to the issue, but between that diagnosis and then actually fixing what's wrong, that won't be a small bill.
I'd try to monitor what the BARO PID shows for ODB-II reading from rest to when it's trying to run. Vacuum line could be clogged, leaking, may need to clean up the EGR passage... But that should show part of the story anyhow. Significantly higher = restriction, lower = leak. If fuel pressure is too high, likely a leak I believe.
The only thing that's odd to me is this came on suddenly, yes? Usually from what I've read this will show up as a DTC, but doesn't kill the engine. Or at least it doesn't right away as in your case.
i was driving along 50mph, and saw the speedometer going down fast, then it felt odd, i thought transmission but that was just rebuilt in february, then it sputtered and died out, all in about 20 seconds time...i have about a 40 minute commute to work and the car ran normal up till that point!
it was towed to the garage that did the transmission and dash assembly for me in february, he seemed good when he had the car back then....so hoping he can figure it out and fix it without big bucks....
