Will the FRPP GT x-pipe fit the 05-09 V6?
Old 12-05-2012, 01:26 PM
AntoThoro
AntoThoro's Avatar
Originally Posted by JimC
You will need a stepped band connector to mate it up because the down tube after the cats is 2.25" and the rest of the exhaust is 2.5" (mid pipe/over axle is the same for the passenger side as the GT, you need just the driver side)
This is my understanding... can you guys double check it....
Location of Pipe: V6\GT
Headers --> Cats: 2.5\2.5
Cats --> Mid: 2.25\2.25
Mid-->Mufflers: 2.5\2.5
so theoretically we should be able to use everything from the headers back from a GT on a V6..? Are there any differences between the V6 and GT cats? Can I buy a GT cats and back to use on my V6?
AntoThoro is offline
Old 12-05-2012, 09:15 PM
Moderator
JimC's Avatar
You can't swap the cats on the V8 and V6 - the size, angle, and placement after the exhaust manifold is different.
It is 2.25" from cats to the mid pipe (X or H) on the V6, but 2.5" for the V8. The mid pipe/over axle is 2.5" all the way back on both cars.
You can use the X or H from the GT, you just have to cut and weld or cut and band AFTER the cats.
Your chart is incorrect and should be:
Headers --> Cats: 2.25\2.5
Cats --> Mid: 2.25\2.5
That is why you will see the stepped band connecting the Y on the stock 4.0 set up to the mid/overaxle pipe.
JimC is offline
Old 12-07-2012, 02:52 PM
AntoThoro
AntoThoro's Avatar
Ah, thanks for the information. I knew I had to have been wrong.
Old 04-24-2013, 01:53 PM
AntoThoro
AntoThoro's Avatar
Are the sizes the same in the 2009 - 2013 mustangs?
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
BeatnikFink
10-01-2015 08:00 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
mdg
10-01-2015 07:04 AM
Quick Reply: Will the FRPP GT x-pipe fit the 05-09 V6?
