TPS Throttle position sensor. Is mine faulty?
Old 06-24-2013, 11:05 PM
asoka05
asoka05's Avatar
Default TPS Throttle position sensor. Is mine faulty?
I have a 2010 Mustang V6. Recently, I am having the following issues:
car threw a P2135 code about 3 months ago. I cleaned the throttle body and reset the code. Car has been fine so far. Until 2 weeks ago, I am having the following symptoms again:
- at highway speed, at 70 MPH, around 2kRPM, my car will have random surging.
- at idle, car will idle rough from 750RPM and drop down to 500RPM and then back up again
- I notice during AC usage, car will idle more rough than usual
I did the following test on the TPS sensor, having key on engine off, I probed the top pin of the TPS(green wire) , the voltage reads 1.26V.
I probed the second pin (yellow wire), it reads 5.04V
Then I moved the TB butterfly from closed to fully open, green wire voltage will read up till 4.53V. While the butterfly opens, voltage increases up till 4.53V with no glitch. When butterfly closes , it will go back down to 1.28V.
My observation: Isn't the car supposed to read 0.9V - 1 V when idle? (My car idles at 1.26V)
When the butterfly is fully open, isn't it supposed to read the maximum 5V? (My car reads max at 4.53V)
Is my TPS sensor faulty?
Thanks
link to video: http://s345.photobucket.com/user/aso...E4270.mp4.html
During idle: (probed the green wire)
Probed yellow wire:
asoka05 is offline
Old 06-25-2013, 03:26 PM
go-part
Former Sponsor
go-part's Avatar
Do you get the same cel?
Have you tried cleaning the maf?
Have you ruled out a vacuum leak or a dirty fuel filter?
go-part is offline
lincolnshibuya
12-08-2015 04:37 PM
UrS4
10-03-2015 06:23 AM
jrrhd73must
10-02-2015 09:17 PM
guitarman376
09-30-2015 05:54 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: TPS Throttle position sensor. Is mine faulty?
