A shudder when it starts
Old 07-03-2013, 05:51 PM
Eismann
Eismann's Avatar
Default A shudder when it starts
Hey guys,
I have a 2005 that when I start the car it shudders for about 5 seconds when RPMs go low then levels off at about 650-700 RPMs. It also does it when I put it back into park. Could this be happening due to needing to clean or possibly replace fuel injectors or could my fuel/air mix be off just a little bit? I know it is getting enough spark since I put on a Screaming Demon coil pack with 8mm wires and new plugs gapped at .64 about a year and a half ago.
Thanks for the info.
Eismann is offline
Old 07-03-2013, 07:27 PM
Nuke
Nuke's Avatar
Clean the throttle body first. That is a likely culprit.
Also, the aftermarket COPs are known for issues. If the TB cleaning doesn't fix it, try re-installing the stock COPs.
Nuke is offline
Old 07-03-2013, 10:17 PM
jimkaray
jimkaray's Avatar
No COP's on the 4.0 but your logic still applies, aftermarket coil packs seem to fail frequenly as do the aftermarket COP's. I would suspect throttle body or IAC valve though based on it acting up at idle.
jimkaray is offline
Old 07-03-2013, 10:55 PM
MustangFirstCar
MustangFirstCar's Avatar
Clean the TB and change your idle to about 900 if you have a tuner
MustangFirstCar is offline
Old 07-04-2013, 07:14 AM
Eismann
Eismann's Avatar
Thanks guys. I will make sure to clean the tb this weekend when I have the car torn apart already.
Eismann is offline
Old 07-04-2013, 11:41 AM
Nuke
Nuke's Avatar
Originally Posted by jimkaray
No COP's on the 4.0...
Yeah, I should have thought that one out. My wife has the 4.0....
Nuke is offline
zsmart
Convertible Tech
02-29-2016 08:33 AM
1TUFF302
11-05-2015 04:02 PM
StalkerGT
09-25-2015 02:41 PM
dalefrancis88
09-11-2015 07:15 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: A shudder when it starts
