Group Buy Aluminum Thermostat Housing! All interested reply to this thread - Page 17 - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 2005-2014 Mustangs > V6 S197 General Discussion > 4.0L V6 Technical Discussions
Reload this Page >
Old 10-06-2018, 11:12 AM
  #161
07 Stang
07 Stang's Avatar
So I read that Ford now sells this. What is the price difference?
07 Stang is offline
Old 10-15-2018, 08:32 AM
  #162
GoHurdler1
07 Stang do you have a link to where it states that Ford Motorcraft is manufacturing the aluminum thermostat? I've only ever seen the third party aluminum thermostat.
GoHurdler1 is offline
Old 12-21-2018, 09:05 AM
  #163
pcfithian
pcfithian's Avatar
Although our 2016 Mustang has the 2.3 Ecoboost, we have a 4.0 SOHC in our 2001 Sport Trac. I posted this over on the Explorer forum, but I wanted to post here as a public service to fellow Mustang owners. Bottom line is you are wasting your time and money on anything other than a Simmons aluminum thermostat housing.
While on a recent trip to Florida, the tensioner pulley seized, destroyed the belt, and caused overheating. This also split the seam on the nylon thermostat housing, which required replacement to get home, more than a thousand miles away. A local NAPA store was great at getting one in from Jacksonville that day, Part No S4402AT by Motorad. As a side note, our local NAPA store stocks these in our town of 30,000 people, indicating high demand for these.
This new plastic thermostat housing started leaking ~ 1,500 miles after I installed it shows evidence of weld line separation and where it leaked.
Of most interest are the date codes on these parts, they were molded several months apart before welding. This is key to understanding the failure.
These parts are molded from glass filled nylon, which will absorb moisture from the air. Nylon parts should be welded together immediately after molding to prevent moisture absorption. This moisture absorption has a great effect on weld strength, as documented in DuPont's literature regarding best practices for welding nylon:
" b. Effect of Moisture on ZYTEL. Nylon resins absorb somewhat more moisture from the air after molding than most other plastics. When released from joint surfaces during welding, moisture causes poor weld quality. For best results, parts of ZYTEL should either be ultrasonically welded immediately after molding or kept in a dry-as-molded condition prior to welding. Exposure of 1 or 2 days to 50% relative humidity at 23C is sufficient to degrade weld quality by 50% or more . . ."
So to fix this, I installed an Austekk aluminum thermostat housing. This also started to leak after ~ 1,000 miles.
This great video explains why:
If you want to do this difficult job once and have it last, an aluminum Simmons Autosportz is the only one I recommend. Check https://simmonsautosportz.com
pcfithian is offline
Old 12-21-2018, 06:51 PM
  #164
07 Stang
07 Stang's Avatar
Thanks pcfithian for showing us the difference and a link to a great price on a "whole" unit. I don't need one yet, only 15k miles but I'm thinking about ordering one anyway for "just in case."
07 Stang is offline
Old 12-22-2018, 04:15 AM
  #165
08'MustangDude
$92.25 eBay:
https://www.ebay.com/itm/BRAND-NEW-A...L/223214777234
$68.75 / $72.85 eBay:
https://www.ebay.com/itm/BRAND-NEW-0...T/223214813879
$45.35 eBay, without sensors:
https://www.ebay.com/itm/NEW-ALUMINU...L/223214823393
They both look the same, except the one sensor hole on the Mustang version is not
drilled and tapped for the 2nd sensor. I am buying the one with both sensors, and just
won't use the other one...
08'MustangDude is offline
Old 12-22-2018, 10:16 AM
  #166
pcfithian
pcfithian's Avatar
Those units are from Austekk. The one I installed leaked at the hose fitting shortly after I installed it, which is why I recommend the Simmons one.
For a few extra $, install one that has the least potential of leakage.
Old 12-22-2018, 03:23 PM
  #167
07 Stang
07 Stang's Avatar
Yeah you can clearly see where the unit is not a whole one piece design. Prone to leaks.
07 Stang is offline
Tivo304
05-30-2018 05:58 PM
carid
07-08-2016 10:55 AM
67LimeCoupe
11-25-2015 09:55 PM
Pyrate Dave
09-10-2015 08:30 PM
Wesley1995
08-30-2015 03:01 PM
Quick Reply: Group Buy Aluminum Thermostat Housing! All interested reply to this thread
Featured Sponsors
© 2018 MH Sub I, LLC dba Internet Brands
