Driveshaft help
I had the aluminum 4" driveshaft from Shaftmasters on my 2006. Great product and great people to deal with. $458 for their product.
http://shaftmasters.com/4mualdr.html
Although I have never heard of upgrading to the 8.8" rear end and tlok causing problems. It doesn't put any extra strain on the rear end at all. I can't see that it is causing any issues like you describe, it doesn't make sense to me.
Essentially a direct bolt in swapping the rear end. However depending upon the year and options on the car it is coming from you may need to replace the pinion flange with the cobra flange.
http://www.americanmuscle.com/frpp-p...0304cobra.html
The V6 driveshaft won't match up to the 2005-10 GT rear end. For a 2011-14 rear end (all Mustangs have the 8.8" in those model years) you have to check the flange. Depending upon the options on the car it comes from it may already have the correct flange.
If you are asking if the Shaftmasters is a direct bolt in, same thing with regards to the pinion flange; unless you call Shaftmasters and order it to be set up for the flange on the rear end that you buy. They will build it to your specs that way so no pinion flange swap, but you have to confirm which flange you have first.
Thanks for the advice
In my 60 years of messing with driveline problems, I have never heard of "staked" U-joints. Add that fact to my years of service as an Engineer with Dana Corp. (ever hear of them?), I know and understand Spicer U-joints inside-out. imp
