Which fuse is for the transmission pressure control solenoid
2007 Mustang 4.0L V6 with 5R55S transmission. Which fuse # is for the transmission's torque converter solenoid/pressure control solenoid? I feel like an idiot because I can't find which one. Also, if you've read this far, does the transmission pan's gasket go on dry or with gasket sealant? Thank you in advance for any responses!
There is no dedicated fuse for that. It's integrated with one of the powertrain fuses. Which one? no clue. Why do you need the info?
Here's a link with both fuse locations mapped (interior passenger and engine bay)
https://mustangforums.com/how-tos/a/...diagram-400063
As for the gasket, its a dry gasket. They say it's reusable but on a 10+ year old car, spend the $15-20 and replace it if it's your first time cracking the pan seal open. Stick with one that has the steel layer in it. Cheap gaskets that are rubber or neoprene only without the steel layer are prone distortion and leaking.
Thank you Derf00. My Torque Converter/Pressure Control Solenoid is throwing a code. The car only goes into reverse and drive (3rd gear, no overdrive or 1st and 2nd gear).. I'm just going to change the solenoid pack, but I was told to check and make sure that the fuse isn't blown. But, if the fuse is linked to other powertrain electronics, then I'd assume that it isn't the fuse considering that everything is running/working great except for the gear shifting issues.
Here's a link to checking the fluid on these dipstickless cars... You do not need the tool to check the level.
Note, you can build the tool they show for under 8 bucks. They want $15 to $20+ for that one. Go to Ace Hardware and Buy two brass fittings. The first is a 1/8" NPT male to 1/4" NPT female thread. The second would be a 1/4" NPT Male thread to whatever tube size you would want to connect a hose to for refilling the fluid later on. I use 3/8" tubing.
Anyways, then just follow the procedure in the video.
Other problems include dying or bad solenoids and bad or worn Servo sleeves in the transmission case. Given the odd gears that do and do not work, the solenoids is the most likely culprit. It's easier, cheaper, and more reliable to replace the Solenoid pack. The solenoids are not serviceable and should not be replaced individually.
I used this site in the past. The staff was very helpful with all of my questions regarding the pack, and the shift kit I bought. Even going so far as to e-mail the instructions for both kits to see what the differences were and help me decide.
https://www.cascadetransmissionparts...noidblock.aspx
You can also get a filter/gasket kit there as well.
chris_2vGT
05-27-2010 06:16 AM
dltexas
04-26-2005 05:05 PM
