2006 4.0 will turn over but not start!
Old 07-18-2019, 01:39 PM
DM mustang
DM mustang's Avatar
Cool 2006 4.0 will turn over but not start!
My 2006 4.0 will start and run for about 3sec and die. New fuel pump, throttle body, fuel pressure regulator, at wits end!
DM mustang is offline
Old 07-19-2019, 09:58 AM
Moderator
JimC's Avatar
Your post was moved to the appropriate section and out from the thread you posted in.
Welcome to the forum and please take time to review the stickies and rules. Please don't make multiple posts of the same thing across the forum, and post in the correct sections.
JimC is offline
Old 07-19-2019, 12:22 PM
don-ohio
don-ohio's Avatar
Did you bleed out the injection rails and fuel lines after replacing pump? Also, are you sure the pump is good,even though new? There are some poorly made pumps out there. I never buy one from Auto-Zone or Advance. Is it at least a Carter,Ford, or NAPA pump?
Also, a key can lose its signature with the computer and need reprogrammed sometimes. Usually a security emblem flashes on the dash.
don-ohio is offline
Old 07-20-2019, 03:59 AM
DM mustang
DM mustang's Avatar
When I jump the fuel pump I get 50lbs at rail, when I tested the pump connector I get 13volts but no fuel pressure
Old 07-20-2019, 04:14 PM
teetertotter
teetertotter's Avatar
Did you check the points pointed out, previously mentioned, leaving you any questions?
This may help too: https://troubleshootmyvehicle.com/fo...he-fuel-pump-1 Read it in its entirety, if you will.
Good luck!
teetertotter is offline
Old 07-20-2019, 11:06 PM
don-ohio
don-ohio's Avatar
Always check/reset the fuel pump inertia switch. Always replace fuel filter with new pump.
don-ohio is offline
Old 07-28-2019, 04:48 PM
teetertotter
@DM mustang , what did you find out? Are you up and running?
makriluc
10-05-2008 10:06 AM
RawGtPower
05-05-2008 04:56 PM
bakedog
01-13-2007 12:39 AM
OnyxCobra
12-11-2006 01:19 AM
88gt vrooom
04-19-2005 10:46 AM
Quick Reply: 2006 4.0 will turn over but not start!
