help please t45-3650 swap
been looking for a while and i can't find answers, my 00 gt t45 is f***ed up [] i found a 3650 a better price, so the questions is, what esle do i need to do the swap, belthousing? or anything else please i really need an answer, thanks
RE: help please t45-3650 swap
Bellhousing, you will need to probably get your ECU reprogrammed to accept the new transmission, new shifter, new driveshaft.
My suggetsion would be to build-up your T-45. Those things can be damn strong if built up a bit.
ORIGINAL: MTShambles
the shifter is diffent i know that if you get it complete with bell housing i would say it should come close to a perfect bolt in swap you may need a new cross member and drive shaft.
Well im assuming that a t-45 might have a different reference signal and so forth than the t-3650, hence why I was thinking ECU reprogramming...
Remember, the gear ratios for the T-45 and the T-3650 are different, so the speedo might be off (hence the difference in RPM's in the calculator between the T-45 and T-3650 Transmissions).
This is mostly an assumption, but it makes sense in my mind.
I wish I could rebuilt it, but I down shifted and the tranny pretty much blew off, I was lucky cuz, the engine is good, but clutch pressure plate, and belthousing are gone, also the encasing broke... im getting the 3650 for $300 from a friend with the driveshaft and everything but i need to know for sure if ai need anything else.... thanks
Matt's 95 Stang
10-05-2015 07:16 AM
