throttle body?
throttle body?
I have seen a few posts recently talking about TB & Plenums. I am aware of the minimal HP gains but, I was wondering if you loose Hp throughout the low and mid range RPM's. I remember reading an article ( not sure which one) but it said you only gain that 1-2 HP around your peak RPM's and you loose it in the low and mid range. Does anyone know if this is true? If it isn't could someone let me know if a 70 or 75 is better for a N/A w/ plenum and other basic bolt ons. Thanks
RE: throttle body?
I think mid-range hp stays about the same until high-rpms where the tb/plenum combo gives you a couple hp. The best thing youll get out of the combo is better throttle response. Also, 70 mm tb is fine...75 mm is overkill.
RE: throttle body?
Check out this forum I posted for you guys with these questions. Has links to dyno charts for TB and Plenum combos. No you do not lose low end HP or Torque. Also, no a 75mm IS NOT AN OVERKILL, just read the forum post and ckeck out the links. It will answer your questions. Make sure you look at all the dyno tests too.
https://mustangforums.com/m_1080031/tm.htm
